tagDiv 8.5 problem
A few days ago I upgraded “Newspaper” theme to version 8.5. I’m trying to add “Hero” component to the beginning of a page that exists in my blog with using tagDiv. In the first stage it works without problem, but when I save the page and open it again then my page is coming empty. The last change I made and all the previous ones are deleting.
Where am I doing wrong?
Thanks in advance for your help.
Please remove your cache plugin and only use wp super cache and these settings: https://forum.tagdiv.com/cache-plugin-install-and-configure/
Also maybe you ave a plugin conflict preventing the tagdiv composer from saving the content properly. Try to test without other plugins as well.
Hello again,
I only use “WP Super Cache” for caching and I use many other plugins on my blog.
But when I deactivated plugin “Accelerated Mobile Pages”, the problem was solved.
I guess this plugin has not been tested and approved by TagDiv yet, am I right?
So, do you have a plugin that you can suggest me instead of “Accerelated Mobile Pages”?
You could try this AMP plugin, this should work with the theme
– http://www.wpbeginner.com/wp-tutorials/how-to-properly-setup-google-amp-on-your-wordpress-site/
If you have identified that plugin to be the cause of the issue, then you could try a different plugin.
