TagDiv _ Big Grid Flex _ Help
Hello, I need your help with the filter while using Big Grid Flex 9. What I want to display in this area is to sort all the contents without depending on the categories on my site and show the next 6 contents after the last 5 contents I added. Where and which filter should I write for this?
I think that you are referring to this option: https://forum.tagdiv.com/offset-feature/. Please check the guide.
Thank you. I solved my problem with offset settings.
I’m glad. Please let us know if you have other questions.
Have a great day!
