please i have some issues with tagdiv amp plugin, i’m using newspaper 9.1 version (fast news demo),when i use amp on my posts the main menu’s logo become left aligned: , and i lose my footer information
and please i need to know if the tagdiv mobile plugin is essential or not and can work with tagdiv amp!
The logo will be left aligned. We based most of the design for AMP on the Yoast SEO website (similar left aligned logo)
– https://yoast.com/social-media-optimization-with-yoast-seo/amp/
The footer information should be the one you set in the theme panel, footer section. The footer text entered there will appear in the AMP version.
The mobile theme plugin can be used together with the AMP plugin. AMP versions of posts will be served by Google through the search results, the rest of the website will use the mobile theme if active. This mobile plugin is optional, when inactive the website will display the default responsive version
– https://forum.tagdiv.com/the-mobile-theme/
Please let us know if you have more questions.
By a setting that is not possible. It will require modifications to the design in the plugin code to make it centered. These will be lost after you update the theme however.
I believe this is on our list of suggestions and will be considered to be implemented in the plugin in the future. Maybe there will be a setting created for this specifically. Sorry for the inconvenience.
Users will be able to access the AMP version of the post only through Google search. Google will serve the page from it’s cache. That would be how Google AMP works.
The rest of the mobile website visitors will see the responsive version of the website or the mobile theme version (if the mobile theme plugin is active).
