tagdiv composer
hi..i cant’t use tagdive composer to edit my homepage
it shows me this message “Error at zones: 6(models) : 1(dom). The model does not match the content Current state has involved an issue. You could try an UNDO operation (CTRL+Z / CTRL+SHIFT+Z)”
how can i fix this?
thank u
1. disable TagDiv Composer
4. install TagDiv Composer
5. activate TagDiv Composer
For this error you can check our guide from here at point 5: https://forum.tagdiv.com/tagdiv-composer-not-working/
Also, try to deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Please also check the page for special characters and remove them if they exists.
it worked..thank you sooooooo much
