Tagdiv composer doesn’ work!
I’ve tried everything, but every time I try to use it, I get:
“Error 404 – not found
We couldn’t find what you’re looking for. Browse our latest stories or try searching using the form below:”
Please help me! I urgently need to publish my website!
Usually, the solution is to add the code from the bottom of this guide – https://forum.tagdiv.com/requirements-for-newspaper/ meaning this one – https://i.imgur.com/q6RyLGA.png in the htaccess file. Then the issue should be solved.
