TagDiv Composer for Posts
Hello
Is it possible to switch TagDiv Composer for Posts edit? How to make the same buttom as on the Page editing? I do not see the possibility to edit Post with TagDiv composer.
Editing actual posts with the tagDiv composer would not be possible, you can edit post templates however
– https://forum.tagdiv.com/tagdiv-cloud-library-plugin/
So you can create a post template with the composer and place what elements you want in it. Then apply it to one or as many posts as you want.
So you mean I will not be able to add elements for each post directly but first I need to create the template for each post? When I used MAG with visual composerit was no disserence page or post I edit. I could easyly put any required element on each post the sane way as for page. It was visual composer button what was very efficiant.
  • This reply was modified 8 years by likocorp.
I understood how does it work. First I create template for each post (if I want them to be different from each other) and then apply this template to the existing post.
Am I right?
Creating the actual post is not possible with the tagDiv composer at the moment, you can create a template and apply that to the post/posts.
So you can create as many templates as you want and apply them for what posts you want, or just one template for all posts. It depends on what you want to do.
