TagDiv Composer Not Loading Despite Increased Resources
Also you can try to change the permalinks save, and try again.
  • This reply was modified 8 years by Calin.
Doesn’t work, so last thing i left is to install this theme with the default name and then after testing i will reply you.
I have try with the default theme name folder (Newspaper) but doesn’t work.
Also update theme and plugin but no luck.
Please go to themeforest log in with your credentials and download the last version of Newspaper theme, and try to test it local ( on localhost ), or on a subdomain.
I already have latest Version 9.1 – October 15th, 2018 and in config i have localhost and plugins are up to date.
One thing i have to say that “td-api-plugin” not installed.
My hosting is GoDaddy…
Viewing 5 posts - 51 through 55 (of 55 total)
