TagDiv Composer not loading – problem? Today Nov 11, 2020
My TD composer is not loading … keep getting spinner. are you having issues Today Nov 11, 2020
Is possible that the problem to be from WordPress version. If you are using the last WP version, then you need to use the last version of our theme, only this is compatible with the new elements from WordPress
Please make sure that you are using last theme version Newspaper v10.3.7 and you have set all the theme requirements as in our guide – https://forum.tagdiv.com/requirements-for-newspaper/
If there is still a problem, please disable tagDiv Composer, delete it and reinstall the plugin from Newspaper plugin, also make a test only with theme plugins.
Let me know the results!
There have been multiple reports of an issue on the forums now.
Hi mcmcghee,
Do you have the same problem ? What theme and WordPress versions are you using? Please provide some more details and a link to your website.
Please notice that the support for WordPress v5.5 was added only in Newspaper v10.3.6.1 if you have a lower version it will not work correctly -> https://i.imgur.com/X1n1o7X.png -> https://themeforest.net/item/newspaper/5489609
Thank you for your understating!
