When Opening Home — Front Page (PRO-Prebuilt Websites) get the following Error message:
Errors at columns elements: 5(models) : 4(dom). The model does not match the content Current state has involved an issue. You could try an UNDO operation (CTRL+Z / CTRL+SHIFT+Z)
Like, I tried one to three pro prebuild websites and still can’t edit the homepage
My Newspaper Theme is Version: Version: 10.4
WP version: 5.7.2
Screenshot of Tagdiv Composer Error:
https://somalieconomic.com/wp-content/uploads/2021/06/Homepage.png
Thank you
In most cases when you get a similar message “ Error at zones: 5(models): 4(dom). The model does not match the content Current state has involved an issue. You could try an UNDO operation (CTRL+Z / CTRL+SHIFT+Z)” then indeed it is a problem, most of the time the problem is from a shortcode that is not compatible with our theme, therefore after you set it with tagDiv Composer and save the page/cloud template, the next time when you try to edit it, you’ll get that error.
For this error, you can check our guide from here at point 5 -> https://forum.tagdiv.com/tagdiv-composer-not-working/ also after trying the steps from our guide you do not get any good results, You can send us an email at contact@tagdiv.com and provide wp-admin login, as well as cPanel and credentials. We will take a look. Include a link to this topic in the email.
Let me know the results!
