Tagdiv Composer Not working on posts
My tagdiv composer is not working on posts. It only shows up on pages. What should I do?
Tagdiv Composer was not designed for posts. It works on pages.
But, if you use tagdiv cloud library you can create a custom post template using tagdiv composer and set it for your posts – https://forum.tagdiv.com/tagdiv-cloud-library-plugin/ – https://tagdiv.com/customize-articles-with-single-post-templates/
