tagdiv composer problem
Hello! I can’t edit the pages of my site zonaburgas.bg with a tagdiv composer. It gives me this mistake -” Error at rows: 5(models) : 3(dom). The model does not match the content Current state has involved an issue. You could try an UNDO operation (CTRL+Z / CTRL+SHIFT+Z) ” What can I do?
Hello @radanoid!
This issue has been already discussed here: https://forum.tagdiv.com/topic/errors-at-columns-elements-5/
Please make sure you did all the steps which I mentioned here: https://forum.tagdiv.com/topic/errors-at-columns-1models-0dom-the-model-does-not-match-the-content-curr/
Check this guide too: https://forum.tagdiv.com/general-options-may-interfere-newspaper-theme/
If this problem is not solved after that, then we need to take a look and see what happened there.
– admin url and credentials
– cpanel url and credentials
Our team will take a look!
I just discovered now that problem was caused from:
“single post reading time” objet (I had recently put it on)
so diagnosis is correct: it is a shortcode element to make error.
Removed element everything works perfectly again.
Hope it helps anybody.
Thank you
