tagDiv Composer Problem
Hi composer makes problem when i try to active it giving this error
https://prnt.sc/cHXIbFFSeFAN
Mobile theme is fixed after changed the php version but the desktop makes problem could you please check this screenshot
https://prnt.sc/zE7eADPmz0Pf
You must install and activate the tagdiv standard pack plugin.
Thank you I have installed all plugin but not tagdiv standard pack it works now very well
I’m glad.
Have a great day!
