Ola guys!
After I update the newspapper theme, I do not see tag div composer when editing the post. For site editing I use WPBakery page builder + MPC addons for WPB. I edit posts using TDC.
Please help!
There could be problems if you use both composers at the same time, this is highly not recommended. Use one only and deactivate the other. It can cause problems with the pages.
Also I don’t know how exactly you edit posts with the tagDiv composer, it can only be used for pages at the moment.
However both composers should appear as an option to edit pages
– https://www.screencast.com/t/kvA3rfMFXTHl
Please check the theme system status parameters
Insufficient resources can cause problems.
Hey,
As Tagdiv composer is not for post so can I use Visual Composer for it?
Also as you mentioned both should not work together so if I disable the tagdiv will it effect the pages that I have created using it?
Please suggest the best way so website is not affected.
Thank you 🙂
Decide on one page builder and deactivate the other. If you have pages built with one of them and you want to use the other, the pages will have to be recreated.
Visual composer should be used only on pages, we do not recommend to use it on posts
– https://forum.tagdiv.com/how-to-use-visual-composer/
If this is absolutely required for you, enable it for posts in the settings of the plugin.
As a side note, we plan to add many more options for the tagDiv composer. There will be a considerable amount of new features added in coming updates. They will be exclusively for the tagDiv composer. You should consider this when making your decision.
Also as a note, if you use Visual composer on posts and activate the tagDiv composer, the post pages layout may not display properly.
