Hello
I have trouble adding a new section with the TagDiv Composer editor. I pull the box and preview panel never finish loading. The same thing happens when I want to save changes, they never finish loading.
I also need to know where I can change the titles of the footer widgets.
Thank you in advance and was attentive to the response.
Ensure that you are using the latest version of the theme installed via FTP way, remove all of the untested plugins, check the system status parameters to be increased according to our documentation from here -> https://forum.tagdiv.com/requirements-for-newspaper/, clear all the caches and check the results.
