I receive a blank window (see image) when I run the tagDiv CSS analyzer. Nothing happens if I press the buttons as well. What am I doing wrong? Or, how can I fix it? Thanks in advance.
This topic was modified 4 years by
nockeeee.
Hello @nockeeee !
Please check before use, the documentation here: https://tagdiv.com/whats-new-in-the-newspaper-theme-10-4-update/
and tutorial here: https://www.youtube.com/watch?v=tnkVapqhIHc
If you can’t see the report, then it could be a plugin conflict or a cache issue. Deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache and try again.
If this problem is not solved after that, then we need to take a look and see what happened there.
– admin url and credentials
– cPanel url and credentials
Our team will take a look!
can u please tell me which cloudflare setting you disabled for soluition
i am facing same problem
Hello shubhamsharma7979,
The last time when we check the CDN settings, those from our guide https://forum.tagdiv.com/cloudflare-cdn/ were working with the tagDiv CSS Analyzer.
Hi nockeeee, in case that one of those settings has been the case of the problem you had, please let us know too, so we can check it out.
