tagDiv Mobile Theme defect, does not change theme correctly on mobile device.
Good evening, I wasted hours and hours reading documentation and looking for a solution and I saw that this plugin tagDiv Mobile Theme, which promises to bring fast and light pages, is defective. I try to put the theme that I use on my website when I go to edit everything is fine, this beautiful theme with a blue header appears, I pulled it via cloud, in the Mobile Theme edition you can see everything is fine, everything is perfect, look, https://ibb.co/cKVCbWMb
The problem is now, I go to access it from my cell phone, to my surprise this theme appears with a black header and totally different from the header and the chosen theme, look at this. https://ibb.co/PB9jXkC
this big defect or bug in the plugin tagDiv Mobile Theme. Is there a solution?? I spent hours and hours trying to solve this.
I don’t have signed up for support, I never asked for help from support, because when I bought it I didn’t even manage to set up the website, after years I’ve been trying to set it up, but it’s difficult, every time it’s a different problem.
I ask for a solution for this?/
When using the tagDiv Mobile Theme plugin, website layout will be changed and specially pages need to be recreated in the mobile editor. This applies specifically to pages, as you can see in the following links: https://forum.tagdiv.com/mobile-theme-introduction/
https://imgur.com/FqDJw8V
This is how the tagDiv Mobile Theme is designed to function, it doesn’t use any builder and is no longer the same as desktop version.
If you prefer a responsive version of the site that mirrors the desktop content, you can simply disable the plugin, and everything will display the same as it does on desktop.
