TagDIV problem
I have a komunikat: Invalid data Current state has involved the issue. What can i do with this? Thank You.
Also make sure that you are using https not http.
Let me know the results!
Hi, I’ve got the same problem.
In Single Cloud Template – Travel PRO i try do upload from library an image on sidebar (image Ad tab), and it shows:
“Invalid data Current state has involved an issue. You could try an UNDO operation (CTRL+Z / CTRL+SHIFT+Z)”
Why?
Let me know, thanks
Hi RiccardoGelli,
Please make sure that you are using last version, Newspaper v10.3.4
Also please make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv Composer, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Make sure that allow_url_fopen = On;
-> https://chemicloud.com/kb/article/how-to-enable-or-disable-allow_url_fopen-in-cpanel/
-> https://www.a2hosting.com/kb/developer-corner/php/using-php.ini-directives/php-allow-url-fopen-directive
I’m Using also Wp bakery, beacause I need a layout with 5 column… and tagDiv let me build only 4 columns… why?
However, I’m using the latest version of theme v10.3.4 and the child theme 9.0c.
I follow the guide about requirements.
I can’t upload In Single Cloud Template – Travel PRO from library an image on sidebar (image Ad tab)…the error is the same.
How can I do?
Hi, can you answer please? Thank you.
Hi, I had a problem with parametr service separation by the server hosting. After i turned off service separation problem was resolved.
Hi RiccardoGelli,
Yes us can achieve 5 columns, you can achieve this using tagDiv Composer, for this on your page or homepage you need to use tagDiv Composer, add a row, this can be stretch and you can choose the layout you want -> https://i.imgur.com/pN6vZwR.jpg let’s that you make those settings -> https://i.imgur.com/ISdhMND.jpg now the row is set in 2 but you need it in 5 so you need to set a width in % on each empty column like this -> https://i.imgur.com/aNtYAfw.png -> https://i.imgur.com/vFhzXBl.jpg after that drag an inner row in each empty column -> https://i.imgur.com/FcUVItl.png -> https://i.imgur.com/wUvuvEl.png -> https://i.imgur.com/MlYoS7f.png and in this way you get the 5 columns.
Also please do not use both plugin (tagDiv Cloud Library and WP Bakery), please choose only one.
but not show not good in mobile views
Please help me to make it clear
Hi khinphearum,
Please provide me a link to your website to inspect the problem and also please, provide some more details and some screenshots about the problem.
I will check you website and try to provide and working solution.
