According to the Newsmag Documentation, it states that we should be able to use AdRotate shortcodes with NewsMag. And that does work, but when AdRotate is enabled, TagDiv Speed Booster disables because of an incompatibility. Is there a way to enable Speed Booster even if the pluggin is not compatible. As far as I can see the site works fine, but now it runs slower.
Hello jmedina0107,
Speed Booster is an optional plugin and it works only with tested plugins. You can read more here and also a solution – https://forum.tagdiv.com/topic/speed-booster-not-compatible-with-vaultpress/
Also, please notice that if you need more website optimizations, notice that you should do it yourself and if you are not aware of the steps which are needed to take in this case, please consider hiring a freelancer/developer to help you because we cannot provide this type of services, sorry! Usually, we recommend the developers from studio.envato.com
