Hello… When I go to Newspaper>System Status. It shows me error as:
Speed Booster v4.9.3 – Disabled – incompatible plugin detected: ad-inserter/ad-inserter.php
Why it is not supporting famous ads plugin ad-inserter. And why speed booster is disabled.
Please solve my issue.
Please check this topic
-> https://forum.tagdiv.com/topic/newspaper-7-speed-booster/
Also you can make the speedbooster to be always active
-> – https://www.screencast.com/t/qJQ0vMuJ
Hello After adding this particular ad code.. it dislays error as: Parse error: syntax error, unexpected ‘add_action’ (T_STRING), expecting function (T_FUNCTION) in /home/jalewa04/public_html/wp-content/plugins/td-speed-booster/td-speed-booster.php on line 86
I have added this ‘ad-inserter/ad-inserter.php’, as mentioned.. But it gives error
Please go back back to the initial set in theme file and try the second option
-> https://www.screencast.com/t/qJQ0vMuJ
We include in speedbooster plugin, those plugins which was tested by us, we can not say if others plugins will work or not, sorry!
Also if the plugin you are using need to be load at the beginning of page than you can not do anything, because if you’ll force it your website will crush.
But if you want you can try with other booster plugin.
