TD-Booster breaks my ads – Help please
I have detected a serious problem with td-booster on my website.
If I use an ad manager, such as “ad-inserter” or “advanced ads” plugin or “adrotate”, the ads go out of the box (container) and my overall score drops drastically.
If I deactivate the td-booster plugin, the ads look good (inside the box). The problem is, that td-booster helps me get a better score on my page, and I prefer to have it active.
Some examples, here I use the plugin td-booster + advanced ads
pagespeed with td-booster + advanced ads
https://fotos.subefotos.com/21aac7829dcb815db8dc3cad65aae42ao.jpg
ads is broket (out of the box)
https://fotos.subefotos.com/a40822f8cfe5326840a4a0928688d2f3o.jpg
Now, I use the plugin td-booster and an ad from the ad manager of the newspapper theme (integrated).
Ad is correct, on box
https://fotos.subefotos.com/0f8380d07b33abce8194e8f1ca79d299o.jpg
Test pagespeed is perfect
https://fotos.subefotos.com/17ec00f67e08b9d564f307403691b232o.jpg
Conclusions
I’m sure my td-booster plugin is misconfigured.
This is my td-booster.php config: https://pastebin.com/wnvh8bnL
With the plugin “advanced ads” + “td-booster” activated, I performed a test modifying the “functions.php” file of the theme.(Siguiendo las instrucciones de esta guía: https://forum.tagdiv.com/how-to-make-the-site-faster/ )
These are the data provided by the theme: https://pastebin.com/MBED8Rgs
But I don’t know what else to do. I can’t locate the problem, nor do I know how to modify the td-booster file (which data I must add, remove or modify).
My programming knowledge is very limited. I’ve only gotten this far.
Can you please help me? What should I do to make the ad manager plugins as “advanced ads” work well next to “td-booster”?
Cheers, Jose
I have added the js and css found to the td-booster plugin:
css
https://fotos.subefotos.com/afbe355fde64e0551ad28850c482b9f3o.jpg
js
https://fotos.subefotos.com/6406a5add0cf4ee91a5d15334fe453b3o.jpg
But the problem can’t be solved. The ad is broken (out of box) and the PageSpeed score is very low.
Is it possible to find a solution to this?
Please follow our guide carefully – https://forum.tagdiv.com/how-to-make-the-site-faster/
Also you can try other plugin for speed booster.
Hi Calin,
I’m sorry, but your answer is not a solution.
I follow the guide ofc:
– Gzip comprension is on
– Leverage Browser Caching is optimiced
– Images are optimiced
– I use a cache plugin
– I use td-booster and remove css and jss on start
My website is ok, The problem is always with “ad managers plugins”, they are not compatible with td-booster.
I have tried to increase the number of advertising options in the theme (ad article in), but is not posible: https://forum.tagdiv.com/topic/any-ads-plugin-compatible-with-newspapper/#post-262785
So, I have a problem with Newspaper theme and I need a solution.
I’ve said many times that I don’t mind paying for a premium plugin, but I need to know that it will work properly (that it won’t cause problems).
But you don’t tell me any either.
So, either help me solve the problem in the newspapper theme, or tell me which ad management plugins are compatible.
You will understand that I have paid for a premium theme, and I have paid 3/4 years for an extra support.
I don’t want you to do a custom job for me, I just want a solution to the problem.
Cheers
Maybe with conditional css will fix the issue. Your issue is same with this post:
https://forum.tagdiv.com/topic/google-matched-content-widget/
  • This reply was modified 7 years by McDohl.
Hi Jose,
I’ve check your website and is look like your have set the ad inline size 1200px, please check the settings of advanced ads and set it property.
This is the size for ad: https://www.screencast.com/t/0R7tpbx5WmV
dis is your ad dimension: https://www.screencast.com/t/tppTl04OVMJ
You can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
Hello @Calin,
Email sent, thank you very much for your support.
I apologize if my comments sounded rude. I have always received very good support attention here.
Cheers
