Hi, I have often issues with tagdiv builder going slow and blank pages within editor.
I don’t have these issues with other tools (ex. elementor) and other websites/connection, what could be the problem? Do you have any advice to fasten the builder?
Please check the requirements here: https://forum.tagdiv.com/requirements-for-newspaper/
Please let me know what host/server you have and what plugins you have installed.
Here from System Status in Theme Option:
php.ini configuration
Server software i Apache
PHP Version i 7.4.33
post_max_size i 256M – You cannot upload images, themes and plugins that have a size bigger than this value. To see how you can change this please check our guide here.
max_execution_time 120
max_input_vars 3000
SUHOSIN installed false
PHP extensions
mbstring available
GD library available
WP version i 6.3.2
WP multisite enabled i No
WP Language i en_US
WP Memory Limit 256 MB/request
WP_DEBUG False
Caching plugin WP Rocket – we recommend WP super cache
Here are the plugins:
Ad Inserter
Settings | Deactivate
Ad management with many advanced advertising features to insert ads at optimal positions
Version 2.7.31 | By Igor Funa | View details | Safe mode
Disable auto-updates
Automatic update overdue by 1 week. There may be a problem with WP-Cron.
There is a new version of Ad Inserter available. View version 2.7.32 details or update now.
Select All In One WP Security
All round best WordPress security plugin!
Version 5.2.5 | By All In One WP Security & Firewall Team | View details
Select Asset CleanUp: Page Speed Booster
Deactivate | Getting Started | Settings | Go Pro
Unload Chosen Scripts & Styles from Posts/Pages to reduce HTTP Requests, Combine/Minify CSS/JS files
Version 1.3.9.3 | By Gabe Livan | View details
Select Better Search Replace
Deactivate
A small plugin for running a search/replace on your WordPress database.
Version 1.4.3 | By WP Engine | View details | Upgrade to Pro
Select Broken Link Checker
Broken Link Checker
Cloud | Local | Docs | Deactivate
Checks your blog for broken links and notifies you on the dashboard if any are found.
Version 2.2.3 | By WPMU DEV | View details
Select Classic Editor
Classic Editor
Deactivate | Settings
Enables the WordPress classic editor and the old-style Edit Post screen with TinyMCE, Meta Boxes, etc. Supports the older plugins that extend this screen.
Version 1.6.3 | By WordPress Contributors | View details
Select CookieYes | GDPR Cookie Consent
Deactivate | Settings | Support | Premium Upgrade
A simple way to show your website complies with the EU Cookie Law / GDPR.
Version 3.1.6 | By CookieYes | View details
Select Easy Custom Sidebars
Deactivate
Replace any sidebar/widget area in any WordPress theme (no coding required).
Version 2.0.1 | By Titanium Themes | View details
Select Easy Table of Contents
Deactivate | Settings | Support | Upgrade | Website
Adds a user friendly and fully automatic way to create and display a table of contents generated from the page content.
Version 2.0.57.1 | By Magazine3 | View details
Select Elementor
Elementor
Activate | Delete
The Elementor Website Builder has it all: drag and drop page builder, pixel perfect design, mobile responsive editing, and more. Get started now!
Version 3.17.1 | By Elementor.com | View details
There is a new version of Elementor available. View version 3.17.2 details or update now.
Select Essential Addons for Elementor
Activate | Delete
The Essential plugin you install after Elementor! Packed with 40+ stunning free elements including Advanced Data Table, Event Calendar, Filterable Gallery, WooCommerce, and many more.
Version 5.8.13 | By WPDeveloper | View details
There is a new version of Essential Addons for Elementor available. View version 5.8.14 details or update now.
Select Fixed Widget
Fixed Widget
Use the fixed widget plugin to create sticky widgets that stay in the visible screen area when the page is scrolled up or down and boost your conversions.
Version 6.2.3 | By Thomas Maier, Max Bond | View details
Select Genesis Simple Edits
Deactivate
Genesis Simple Edits lets you edit the three most commonly modified areas in any Genesis theme: the post-info, the post-meta, and the footer area.
Version 2.3.1 | By StudioPress | Visit plugin site
Select Header Footer Code Manager
Header Footer Code Manager by 99 Robots is a quick and simple way for you to add tracking code snippets, conversion pixels, or other scripts required by third party services for analytics, tracking, marketing, or chat functions. For detailed documentation, please visit the plugin’s official page.
Version 1.1.36 | By 99robots | View details
Select Hotjar
Hotjar
Deactivate
The fast & visual way to understand your users.
Version 1.0.16 | By Hotjar | View details
Select HTTP2 push content
HTTP2 push content
Settings | SEND SUGGESTIONS TO IMPROVE | Deactivate
Push all CSS and JS file throuhg http2 server, plugin add extra files that you want to push like images font files and other
Version 1.9.71 | By Pi websolution | View details
There is a new version of HTTP2 push content available. View version 1.9.72 details or update now.
Select Imagify
Imagify
Settings | Bulk Optimization | Documentation | Deactivate
Dramatically reduce image file sizes without losing quality, make your website load faster, boost your SEO and save money on your bandwidth using Imagify, the new most advanced image optimization tool.
Version 2.1.2 | By Imagify – Optimize Images & Convert WebP | View details
Select Inline Related Posts
Settings | PREMIUM | Deactivate
Inline Related Posts AUTOMATICALLY inserts related posts INSIDE your content, capturing immediately the reader’s attention
Version 3.3.1 | By Data443 | View details
Select Lightweight Social Icons
Deactivate
Add simple icon font social media buttons. Choose the order, colors, size and more for 42 different icons!
Version 1.1 | By Thomas Usborne | View details
Select myStickymenu
myStickymenu
Activate | Delete
Simple sticky (fixed on top) menu implementation for navigation menu and Welcome bar for announcements and promotion. After install go to Settings / myStickymenu and change Sticky Class to .your_navbar_class or #your_navbar_id.
Version 2.6.5 | By Premio | View details
Select Post Duplicator
Post Duplicator
Deactivate
Creates functionality to duplicate any and all post types, including taxonomies & custom fields
Version 2.31 | By Metaphor Creations | View details
Select Post Tags and Categories for Pages
Deactivate
Simply adds the stock Categories and Post Tags to your Pages.
Version 1.4.1 | By curtismchale | View details
Select Post Type Switcher
Post Type Switcher
Deactivate | Sponsor
A simple way to change a post’s type in WordPress
Version 3.2.1 | By Triple J Software, Inc. | View details
Select Post/Page specific custom CSS
Post/Page specific custom CSS will allow you to add cascade stylesheet to specific posts/pages. It will give you special area in the post/page edit field to attach your CSS. It will also let you decide if this CSS has to be added in multi-page/post view (like archive posts) or only in a single view.
Version 0.2.4 | By Łukasz Nowicki | View details
Select Redirection
Redirection
Manage all your 301 redirects and monitor 404 errors
Version 5.3.10 | By John Godley | View details
Select Sensei LMS
Sensei LMS
Activate | Delete
Share your knowledge, grow your network, and strengthen your brand by launching an online course.
Version 4.18.0 | By Automattic | View details
There is a new version of Sensei LMS available. View version 4.19.1 details or update now.
Select Sercanto
Sercanto
Deactivate
Sercanto Widget Plugin
Version 1.0 | By Sercanto | Visit plugin site
Select Shortcodes Ultimate
Shortcodes Ultimate
Deactivate
A comprehensive collection of visual components for WordPress
Version 5.13.2 | By Vova Anokhin | View details
Select Simple Author Box
Simple Author Box
Configure Author Box | Deactivate
Adds a responsive author box with social icons on any post.
Version 2.52 | By WebFactory Ltd | View details
Select Site Kit by Google
Site Kit by Google
Site Kit is a one-stop solution for WordPress users to use everything Google has to offer to make them successful on the web.
Version 1.111.1 | By Google | View details | Rate Site Kit | Support
There is a new version of Site Kit by Google available. View version 1.113.0 details or update now.
Select Sucuri Security – Auditing, Malware Scanner and Hardening
Deactivate
The Sucuri plugin provides the website owner the best Activity Auditing, SiteCheck Remote Malware Scanning, Effective Security Hardening and Post-Hack features. SiteCheck will check for malware, spam, blocklisting and other security issues like .htaccess redirects, hidden eval code, etc. The best thing about it is it’s completely free.
Version 1.8.39 | By Sucuri Inc. | View details
Select tagDiv Cloud Library
Deactivate
Access a huge collection of pre-made templates you can import on your website and customize on the frontend using the tagDiv Composer plugin.
Version 3.0 | built on 05.10.2023 12:50 | By tagDiv | Visit plugin site
Select tagDiv Composer
tagDiv Composer
Deactivate
Create everything on your website right on the frontend with this drag and drop builder. Perfect for articles, pages, headers, and footers. No coding skills required.
Version 4.4 | built on 05.10.2023 12:50 | By tagDiv | Visit plugin site
Select tagDiv Opt-In Builder
Deactivate
Generate leads and increase conversion rates with opt-in content lockers and subscription lists. tagDiv Opt-In Builder helps you easily create content lockers, subscribing lists (membership) and gives your visitors a compelling reason to enter their email address (opt-in) to unlock your content.
Version 1.5 | built on 06.10.2023 12:11 | By tagDiv | Visit plugin site
Select tagDiv Social Counter
Deactivate
Displays your activity on social networks with style. Use it as a cool widget or shortcode.
Version 5.4 | built on 06.10.2023 12:11 | By tagDiv | Visit plugin site
Select tagDiv Standard Pack
Deactivate
Standard Pack Support
Version 2.1 | built on 06.10.2023 12:11 | By tagDiv | Visit plugin site
Select Tawk.to Live Chat
Tawk.to Live Chat
Embeds Tawk.to live chat widget to your site
Version 0.8.1 | By Tawkto | View details
Select The Moneytizer
The Moneytizer
Plugin of the ad network The Moneytizer that facilitates the integration of your ad tags
Version 9.5.20 | By The Moneytizer | View details
Select To Top
To Top
To Top plugin allows the visitor as well as admin to easily scroll back to the top of the page, with fully customizable options and ability to use image.
Version 2.5.2 | By Catch Plugins | View details | Support Forum |
Select UpdraftPlus – Backup/Restore
Premium / Pro Support | Settings | Deactivate | Take Tour
Backup and restore: take backups locally, or backup to Amazon S3, Dropbox, Google Drive, Rackspace, (S)FTP, WebDAV & email, on automatic schedules.
Version 1.23.10 | By UpdraftPlus.Com, DavidAnderson | View details
There is a new version of UpdraftPlus – Backup/Restore available. View version 1.23.11 details or update now.
Select WP Reset
WP Reset
Open WP Reset Tools | Deactivate
Reset the entire site or just selected parts while reserving the option to undo by using snapshots.
Version 1.98 | By WebFactory Ltd | View details | Support | Plugin Homepage | Rate the plugin ★★★★★
Select WP Rocket
WP Rocket
Settings | FAQ | Docs | Support | Deactivate
The best WordPress performance plugin.
Version 3.9.3 | By WP Media | Visit plugin site
Auto-updates disabled
Select WPForms Lite
WPForms Lite
Get WPForms Pro | Settings | Docs | Deactivate
Beginner friendly WordPress contact form plugin. Use our Drag & Drop form builder to create your WordPress forms.
Version 1.8.4.1 | By WPForms | View details
Select Yoast SEO
Yoast SEO
Get Premium | FAQ | Settings | Deactivate
The first true all-in-one SEO solution for WordPress, including on-page content analysis, XML sitemaps and much more.
Version 21.5 | By Team Yoast | View details
– In theme panel I set to NO DISPLAY CATEGORIES, POST VIEWS, COMMENT COUNT, ETC. in single posts: https://prnt.sc/BsebkJ658K4e
– but not working: https://prnt.sc/Y5bQ9AKgam2R
Please let me know if you have the undo and redo settings enabled, if yes, then please disable it from Website Manager -> https://forum.tagdiv.com/tagdiv-composer-website-manager/
Also, I recommend doubling the wp-memory limit.
Hi, I can’t see the answer to this question:
– In THEME PANEL > POST SETTINGS, I set to NO DISPLAY CATEGORIES, POST VIEWS, COMMENT COUNT, ETC. in single posts. Screenshot: https://prnt.sc/BsebkJ658K4e
– But it’s not working. Screenshot: https://prnt.sc/Y5bQ9AKgam2R
You need to edit the post with tagDiv Composer => https://www.screencast.com/t/jHatJGC1qRf, for example, select the Single Post Views => https://www.screencast.com/t/NhUGCRfI and with right-click, you can delete it.
Also, you can delete other elements.
