Here is the error I’m getting:
TD Composer Internal error: The system tried to use an att that does not exists! class_name: vc_row Att name: “tdc_css_class_style” The list with available atts is in tdc_composer_block::render
/var/www/okinawahai.com/wp-content/plugins/td-composer/includes/tdc_composer_block.php > get_att
Hello theg1819,
Please notice that our theme has been fully tested before releasing and we have not encountered any type of error in this regard, sorry! Please try to re-install the theme via FTP way according to our documentation here -> https://forum.tagdiv.com/newsmag-install-via-ftp/ Use only our tested and required plugins which come bundled with the theme core files and check the results.
Make sure you update the plugins AND the theme together; delete old folder, don’t ‘overwrite’ old ones.
Clear transients with WP-Optimize plugin
Resave permalinks
Works for me doing that.
(also: make sure you’re using PHP 5.6 or higher; as older versions will not work well with most current WP updates, plugins, code, etc. — and older versions are ‘end of life’ now, esp 5.2/5.3).
This reply was modified 9 years by
simchris.
Hello theg1819,
To be sure if you have the latest theme version you should download the theme’s packet from Theme Forest and then install it via FTP way because this is the surest method in this case, according to our documentation here -> https://forum.tagdiv.com/newsmag-install-via-ftp/ To bring the best theme results, notice that you should use only the plugins that come bundled with the theme packet.
I did it and thought everythings was going well but there seems to be some issue while viewing on smartphones. I inspected the page and came up with this error
:tagdiv_theme.min.js?ver=8.1:174 Uncaught TypeError: Cannot read property ‘replace’ of undefined
Frames show up empty on the site.
Hello theg1819,
Please notice that our latest theme version was fully tested and after many tests seem to work as expected. If you are using some untested plugins, try to disable all of them, leave just only the plugins which come bundled with the theme core files and use only required plugins and check the results. If you are using some untested plugins, you should disable all of them, clear all the caches and check the results. It seems to be JS issue which can break your theme functionality. Maybe exists some corrupt js files. To avoid this reasons, you should try making a new clean install, from scratch.
Hello theg1819,
Should work as expected if the theme was right installed according to our documentation. Please notice that our theme, before releasing it was fully tested and should work as expected. If the problem is still there, you should try to create a new subdomain and install there the theme and check the results. Use only the plugins that come bundled with the theme core files and if you are using some untested plugins, you should remove all of them because all of these might interact with the theme core files and causes a lot of unknown issues.
Hello theg1819,
Please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further inspect it closer your setup page. Provide there the link to this code so we can quickly identify you.
