TD Composer block problem and Popular 7 days posts not working
I’m having some issues regarding the TD Composer. When I try to add a Block 4 in preview mode it works properly but as soon as I update and save the changes it breaks. I’ve added a screenshot so you can see what’s going on. I also tried to clear cache on server and browser but the error persists.
TD Composer view
After saving settings and publishing
The second issue is when I try to set under Block 11 -> Filter -> Sort order -> Popular (last 7 days). It won’t show only the post from the last 7 days instead, it shows me posts from 2 months ago.
The URL is: https://www.inspireme.hr/
It is unusual that when placing the block in your case in a split row, block 4 seems to display 3 modules, this block will only display 3 modules when placed on a full row
– https://demo.tagdiv.com/newspaper/block-4/
Blocks should only be placed in these layouts
– https://www.screencast.com/t/qSPrVFLrZp
If placed in a different row layout they might not be displayed properly.
We could take a look if you could provide admin login details by email at contact@tagdiv.com we will investigate. Include a link to this topic in the email.
That sorting option requires post views to be active, I see they are on your website. Now you must enable an option in the theme panel
– https://forum.tagdiv.com/7-days-post-sorting/
As soon as you enable that option, the count will begin. Posts will gather views and they will begin showing up in the block based on the page views they get. Note that this sort will not work with caching plugins.
