Since some days I have a problem with my website, I got a lot of “403 and 404 Forbidden/Not Found The requested URL was not found on this server.” error message.
I contacted the hosting company they said that the TD Composer causing the problem, they give me this error log:
Fatal error: Allowed memory size of 67108864 bytes exhausted (tried to allocate 32 bytes) in /home/o0842418033888/html/wp-content/plugins/td-composer/legacy/common/wp_booster/td_util.php on line 167
Can you help me to fix the problem?
Hello !
Make sure that you have accomplished all the system requirements as in our documentation here: https://forum.tagdiv.com/requirements-for-newspaper/
Let me know the results!
Usually this issue is related to a firewall or security module which blocks admin-ajax.php request. Please verify the console for error while saving the settings on the Theme Panel, usually it displays a 403 or 404 error.
If you don’t use a security plugin, please ask your host about this, maybe you have a security module which blocks this.
If you use a plugin like Wordfence please set it in learning mode.
Hi Calin, I have same problem! Can you, please, explaine me this:
“Please verify the console for error while saving the settings on the Theme Panel, usually it displays a 403 or 404 error.”
Where should I verify console? I don’t know where is located, on my website or plesk panel?
Hello, @Sonjita,
If I understood correctly, you don’t know how to inspect the theme Panel problem, right?
So, when you save in the theme panel, click right and select “Inspect” you will see the DevTools, select the Console and you will see if you have an error => https://www.screencast.com/t/vJjPIgPTdW
Hope this helps you!
