TD Mobile Plugin Top Grid shows outdated article or posts
My website http://www.biliranisland.com/blogs shows the outdated posts.. How to correct this one? I want the latest post in the Top Grid.
https://prnt.sc/h2mnki
The Mobile Theme plugin comes with predefined homepage: the Grid which displays 3 featured posts – https://forum.tagdiv.com/featured-posts-2/ and latest articles section.
If you want to display the same content like you have on desktop, you can deactivate Mobile theme and use the default responsiveness as the theme has already a mobile version.
If you want to use Mobile Theme and you want to change the Grid configuration, you will need to modify the code – https://www.screencast.com/t/gHCyVAPiNKTl
It works now, the problem now is the offset.
  • This reply was modified 9 years by jalmz.
Try setting an offset for the Latest articles – https://www.screencast.com/t/VbS1Sv4OkU
The 3 posts from the top grid should not be displayed in the Latest articles anymore.
It works now.. thank you so much
