TD Revolution Slider Element from TD Composer does not work properly…
Hi Team,
I have created a revslider and I tried to use the Element “Revolution Slider” to add to my page.
I can add but the design gets scrambled, the slider images get cut in half, very weird.
Slider screwed using TD Composer shortcode
So, I tried to add the [revslider shortcode by myself inside a “Column text” element. IT WORKED. Slider shows perfectly.
But then, when I exit and reopen the TD Editor, I get error “Reply To: Error at rows: 7(models) : 1(dom). The model does not match the content”.
Then, I go to the WordPress editor, remove the shortcode I added [revslider… I can now edit the page via TD Composer, but I’m out of Revslider.
Not sure what to do.
I’m sharing the page below with the TD Composer slider code.
If you go to the second slide, you can clearly see that the image is cut in half.
Please advise.
http://server.rpbr.me/wsp/backup-em-nuvem-para-empresas/funcionalidades/
  • This topic was modified 7 years by wspeed. Reason: include image
For Error at rows: 7(models) : 1(dom)
WP_MEMORY_LIMIT try to increase it at least to 256mb.
Please check the settings from Slider Revolution -> https://www.screencast.com/t/VU7exfi7s -> https://www.screencast.com/t/PCOl138FXh7
Also check this article ->https://www.somnathjadhav.com/set-zoom-effect-in-revolution-slider-for-background-image/
Slider Revolution WordPress 5.x Documentation -> https://www.themepunch.com/revslider-doc/slider-revolution-documentation/
You’ve nailed on Also check this article ->https://www.somnathjadhav.com/set-zoom-effect-in-revolution-slider-for-background-image/
The problem was the Ken Burns effect. I disabled in all of the slides and now it’s working. Thanks Calin. You can close this.
