hi.
How to make TD Speedbooster plugin can be used in wordpress? this plugin can not be used with other plugins like cloudflare, akismet, ad inserter and other plugins. Should I choose which plugin is better? do i have to remove cloudflare, akismet, ad inserter or plugin TD Speedbooster? https://www.screencast.com/t/Jw2gQ1hqvhht
Speed Booster is an optional plugin and it works only with tested plugins. You can read more here and also a solution – https://forum.tagdiv.com/topic/speed-booster-not-compatible-with-vaultpress/
@dperryamg Please check again, the link provided above works.
