Hello there;
I use instagram block shortcode for the post, it works on desktop browser without any problem, but on mobile theme it shows shortcode text. Here is the sample code,
[vc_row][vc_column][td_block_instagram instagram_id="someidhere" instagram_header="off"
instagram_images_per_row="2" instagram_number_of_rows="5" tdc_css=""][/vc_column][/vc_row]
Any suggestions?
On the mobile theme, no visual composer blocks will work at all. The mobile theme does not use visual composer so any at all block will not be rendered. This guide describes this information: https://forum.tagdiv.com/the-mobile-theme/
