Templates displaying in another language / other load issues
We’re trying to choose different templates, but they’re displaying in foreign languages and can’t change the language—
We also have an issue with trying to get pre-load articles to appear in new templates
And another issue is newspaper12 logo flashes briefly before showing ours every time when loading our website
You need to translate the English (original language) header for each language in part – https://i.imgur.com/CDmeHCf.png you should have them for each language cloud template – https://i.imgur.com/4agmUtg.png -> https://forum.tagdiv.com/using-theme-translations-together-wpml/
A much simpler and faster alternative is to duplicate the cloud template you want to use in another language, edit it and select the desired language – https://i.imgur.com/z1CqgBo.png (edit the name) – https://i.imgur.com/dPX8ROs.png – https://i.imgur.com/Lc81IgP.png This method needs to be used to translate all cloud templates.
The pages are created with tagDiv Composer which is a page builder, when WPML is used it cannot translate everything that was built with the page builder and must be edited for each language separately. Please open the page in the editor and click on translate – https://i.imgur.com/TXH6y1c.png
When you make the corrections, make sure you are on the page with the language you are editing, and if you use the cache, or object cache, please clear it.
