Text color problem on Black Pro pre-built theme
Hi, after I install the Black Pro pre-built with content, nothing happened. The background color is nearly black and the text color is white.
But when I write my own post with Gutenberg editor, the text color (including post title, content, …) has a black color similar to the website background color.
Link: https://pyzone.dev/start/
I have not added any extra custom CSS. So please help me find out this problem, thank you.
Update #1: The problem also appears when using the classic editor.
I notice that you don’t use the Single Post Template Black pro, but another template.
Please make sure you have set the Single Post template assigned global -> https://i.imgur.com/r4qaMgW.png -> https://i.imgur.com/PGCNsCS.png
Thank you for your support. As your guide, I found that I changed the default post template (site wide) in Theme Panel > Post settings from Single template to Default. After changing back to “Single template”, Now it’s ok with text content. But the title (h2-h6) is still black as the background color. You can see it here: https://pyzone.dev/start/
I have looked at your demo at https://demo.tagdiv.com/newspaper_black_pro/ and don’t see any heading on your posts.
Update: The image caption also has this issue.
All the changes you need to do with tagDiv Composer, in the Single Post Template.
Also, make sure you have set the content in the content section, not the header -> https://www.screencast.com/t/32BrYI5A
Please check this video about how can create a website from scratch https://www.youtube.com/watch?v=SoGQ0d5kIBg
Thank you,
Now I got how to fix it, and also how to customize it with any other color value.
If you have other questions related to our theme, please let us know!
Have a great day!
