Text color setting problem
https://www.hpay.info/cookie-policy/
In the form automatically generated by the plugin, the color of the content can be changed, but the color of the title cannot be adjusted. Ask for the solution
You can change the color of the posts like this, edit with Composer, and select the page title -> https://i.imgur.com/lOXQ5bs.jpg in the backend you can’t change, also, those are our testing plugins https://i.imgur.com/PLzesV2.png
There are two more questions:
1. How to enable the article comment function? I have tested several plugins and found that the comment function cannot be enabled.
2. I’m actually deeply involved and using gettr as well. Very surprised to see the gettr social sharing icon built into our template. But the icon display is not very clear, it would be better if a clearer version of the logo can be replaced (I can coordinate to provide the icon).
  • This reply was modified 4 years by roger086. Reason: change
GDPR Cookie Consent:
DESCRIPTION:
I tried changing the color of the description, but the color of the title still can’t be changed
That is: “GDPR Cookie Consent” plugins are not compatible right? Do you have any other recommended cookie plugins?
1. The comments section on the post can be displayed only f the post is unlocked or is not locked in the first place. So please add a new post and check be sure that is not locked and check it to see the comments should be displayed like this -> https://i.imgur.com/E0icIRg.png -> https://i.imgur.com/oYTx2RT.png
2. For this please try this custom css
https://i.imgur.com/WIpPxEM.png
.td-icon-gettr:before {
font-size: 30px;
line-height: 0.6;
Set the code in theme panel> custom code> custom css
About changing the color, did you tried using the tagDiv Composer on that page? Or using the theme panel settings?
hi,Calin!
I`m Very happy to receive your reply.
Icon size problem solved! Learn a new way with you! Thank you very much for your support!
1.Gettr.com: The icon of gettr, the new version is (vertical flame version), which means that there is no distinction between left and right political factions.
I can provide a new version of the icon if needed.
2.Because the text in the table is generated by the plugin itself. I tried to use the tagDiv Composer , can’t edit. In the background, you can only edit the color of the description text on the right side of the table. The text on the left side of the table is the title text in the background of the plugin, and the color cannot be adjusted.
Black theme, there will be display problems. You can also try to install this plugin in the background: “GDPR Cookie Consent” to test it.
3.ABOUT Exchange Shortcode:
https://forum.tagdiv.com/exchange-widget/
https://fixer.io/
This feature is great! According to the guidance of the tutorial: I applied for the api, but it keeps prompting that the api is wrong~
Exchange widgetExchange API error: Error response from server, the key may be invalid
In fact, the api is correct.
key: 548a2d8d38f7c50d85e40002a533816f
coinlayer
https://coinlayer.com/
For our website, we need this encrypted api data display. How can I call the code to display it on the homepage of the website?
If you want to change the icon this can be done with css, if you can give me the icon I will make a css for you.
The problem with the color in the table, it seems that those are coming from the plugin (like you said the color is not for a back website) and the theme can not overwrite them, you can can use a custom css -> https://i.imgur.com/AHqorwl.png
table.cookielawinfo-classic td{
color: #fff;
The Exchange widgetExchange API indeed seems to not be ok, you need to create a new one, because I do not know why, but this one is not valid -> https://forum.tagdiv.com/exchange-widget/
https://mega.nz/file/pJICQZZL#vu4jVB1D7HiXveBvK55_xtpVJpz19nOk7bIeesg0RZk
This is the new version of gettr’s official logo material. Please help to update. Thanks!
It would be great if the share icon for gettr could be added here!
gettr share
Hello @roger086 !
This will require custom work which is not covered by the support team.
For customization and other services you can contact our custom work team here: https://tagdiv.com/premium-customization-services/
Thank you for understanding!
Here is gettr nes icon, Please change,thank you!!
https://mega.nz/file/wZwFFA7Z#MAYrse64xWy-laPhbKiDdTpU97P22aG80D4_lNiydwM
Hello @roger086 !
– admin url and credentials
We will take a look and try to help you!
