the "DISABLE FOR ADMINS/EDITORS" function does not work correctly
Hi all, when we enable “DISABLE FOR ADMINS/EDITORS” in “ADS” Adsense ads are disabled for everyone. Even for unregistered users. How can I fix this? Thank you
Can you please provide an example of what you’re trying to achieve and where the issue is?
Hi Bettina,
we have uploaded an Adsense ad in Newspaper – Theme panel – Ads – Costum Ad 1 and activated DISABLE FOR ADMINS/EDITORS. In this way the announcement is not seen by the Admins/editors but normal visitors do not see it either.
With the DISABLE FOR ADMINS/EDITOR command, the announcements are not seen
Do you use default templates or cloud templates?
In the cloud templates, you can add the ads when you edit the post with TagDiv Composer in the element called ” Single Post Content ” in the tab ADS. Documentation here: https://forum.tagdiv.com/article-ads/
Or you can use the element called “Ad box” from TagDiv Composer, and there you need to add the ads: https://forum.tagdiv.com/ads-adsense-overview/
