The model does not match the content. Again, and again, and again, and again…
Hi everybody,
So, after getting tired of some frequent issues I decided to rebuilt my entire website from ground up.
Everything was running smoothly as expected.
Until, out of the blue, I’m getting the same old “The model does not match the content Current state has involved an issue of Death”. https://prnt.sc/wypi0b
I really got tired of rebuilding the same page over and over and over and over again.
I appreciate if you could help me with (URGENT) assistance.
Thanks for your always helpful cooperation.
All the best.
After further analysis, I found this errors thru the Health & Diagnostics plugin:
https://prnt.sc/x3nl0i
Do you believe this is related to the issue I’m getting with my website?
If so, any clue where should I start looking to solve this issue?
Thanks once again.
I managed to fix the cURL issue and the problem with TD persists.
For this you can check our guide from here at point 5: https://forum.tagdiv.com/tagdiv-composer-not-working/
Also, try to deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Please also check the page for special characters and remove them if they exists.
Hope that helps you!
