Hi, I’d like to report that the Metro Pro’s translation function does not work on my website, no matter how I choose the language ( such as Chinese(Simplified)) , after I chose, click “save settings”, it is keeping the saving circle and never end. Nothing could be changed.
Our theme is a frontend theme for most of the elements and changes, you’ll need to use the tagDiv Composer to edit the pages and templates for posts/categories, etc => https://i.imgur.com/I3OUYxr.jpg -> https://i.imgur.com/mMrEufY.jpg
If your settings are not saved, please check this topic -> https://forum.tagdiv.com/topic/newspaper-theme-panel-settings-are-not-being-saved/
Please let me know if you check the topic if the settings from the theme panel are not saved.
Depending on what you need to translate, some settings are applied from Theme Panel, others need to be done with tagDiv Composer. For example, if I want to translate the “Load more” for pagination -> https://i.imgur.com/MLw2vKp.png, need to change the translation from Theme Panel -> Translations -> Translations -> https://imgur.com/EB0auPP, if I need to change this title I can do it with tagDiv Composer -> https://i.imgur.com/4ZWlpmo.png
Hello Michael,
To change the font on block/post you can edit with tagDiv Composer -> https://prnt.sc/10grx77 , select the block/post and in Style, you can change the font => https://www.screencast.com/t/sUE7ug4UIAR5 also, after you can copy the style and paste it -> https://i.imgur.com/WCHxXlr.png
This is a video about how to change the fonts => https://www.youtube.com/watch?v=jQvA64uTLkI -> https://forum.tagdiv.com/font-customization/
Hope this helps you!
Dear Anamaria,
I have tried as you suggested, deleted the file wp-cache-config.php in wp-content folder, but the problem(translation language change saving) has not solved.
I don’t understand the process of object catche on backend,
https://www.screencast.com/t/RGAmXzLoXpxw, would you give me more detail instruction on this?
Michael
Could you please tell me what the issue is, and whether it is related to translation or fonts?
As I said the fonts needs to be edited with tagDiv Composer, like in the video https://www.youtube.com/watch?v=jQvA64uTLkI
You can find more details about object cache in this guide -> https://wp-rocket.me/blog/object-caching-use-wordpress/
