I have been using smart list2 for all my articles, and for ads I’m using header ads – http://curiosityhuman.com/ , as u can see ads are appearing, also here – http://curiosityhuman.com/top-10-hottest-women-world-2016/ , but here in another post ads are not appearing – http://curiosityhuman.com/top-10-adult-bollywood-movies/ .. but by viewing from WordPress preview changes – I can see ads – http://prnt.sc/c0929y , Once I deleted the caches , ads start appearing after loading page , that disappeared, let me know if u required more details , and plz help me to fix this.
I have checked your site and the ad code is there – http://screencast.com/t/ku0Xlrqa
Do you say that when you clear cache the ads appear also on that post? Then I guess it is a problem with you cache plugin configuration. Try to delete all the caches and then disable all your plugins except Visual Composer and see if they appear. We recommend Wp Super Cache plugin with this configuration – https://forum.tagdiv.com/cache-plugin-install-and-configure/
the theme only render ad-sens code but cannot control its content. As can be seen in this screen the ad-code it’t rendered but google deliver a blank ad: http://screencast.com/t/hypYW4sw8 Check this link for more details about this situation: https://support.google.com/adsense/answer/1208336?hl=en
