I have a dark theme, black background and white text, on my website. It works well on the desktop but in the mobile version the posts do not have it, they are displayed with a white background and black text. the website is https://tequilademaya.com
No, and although the homepage and categories are working correctly the posts, shopping pages and any page that is not the homepage have a white background with black text.
Hello @detaylor!
If you mean that sidebar, then this can be modified only from the theme panel -> post settings -> more article box.
But, unfortunately, there are no settings for colors because it is an old layout. You can change the color with some CSS: https://forum.tagdiv.com/create-custom-code-using-the-browsers-inspector/
OMG do you even look at the website you are troubleshooting? I am NOT using any sidebars anywhere on the website.
I am talking about the issue of colors displayed on the mobile version of the website. I am using a black background with white text however on the mobile version of an actual phone it is displaying a white background with black text on the post pages. If you look at the mobile version in an emulator it shows correctly but on an actual phone, iPhone or Android, it has a white background with black text. The header and footer and in the correct color scheme but the post content is displayed with a white background and black text, the exact opposite of what it should be.
Use this page as a reference and actually look at it with a cell phone:
https://tequilademaya.com/long-island-iced-tea/
Hello David!
I’m sorry about the misunderstanding, but any extra info, screenshot, or video should be a good hint.
The problem there is the AMP layout, which is running there. That’s why it is white and a different template. When you enable the mobile theme plugin with AMP, then it will overwrite the templates with their layout. This layout has some settings only in order to customize the design in the theme panel. Please read all about AMP here: https://forum.tagdiv.com/tagdiv-amp-plugin-tutorial/
