I just purchased Your theme.
It looks good since I try to change anything.
Firstly I uploaded theme, then installed demo with content.
Whenever I try to change anything, for example a footer info and save those changes it doesn’t appear on website.
Its changed in theme panel, but its not on website.
What is going on ?
a) make sure you fully cleared cache in site/cdn and browser
b) make sure you have enough memory allocated to WP in your wp-config.php file (default 40MB not enough to use Visual Composer!)
c) make sure you don’t have conflicting plugin causing javascript errors in your browser (see: F12/console in Chrome or Edge)
d) most often if changes are seen in the admin panel, but not on the site it’s a caching issue, where the original version pre-change still being shown or cached in your browser
(( I don’t work here … ))
Wordpress docs (“codex”) a great way to learn how to use WP, btw;
https://codex.wordpress.org/Editing_wp-config.php#Increasing_memory_allocated_to_PHP
add to wp-config.php
define( 'WP_MEMORY_LIMIT', '96M' );
hope that helps! 🙂
(( I don’t work here . . . ))
Hello matpl,
You have to increase these values in order to achieve the best result. If you do not have access to your system status file, please contact your hosting provider and then try to increase these parameters.
Please make sure your system status parameters are set properly. You can check here: http://screencast.com/t/Ka9cF6ty and then you can use this guide to see how you can increase these values: https://forum.tagdiv.com/system-status-parameters-guide/
Please check and this -> https://forum.tagdiv.com/how-to-update-visual-composer-plugin/ and make sure that you are using the latest version of Visual Composer.
->> https://forum.tagdiv.com/how-to-use-visual-composer/
Thank you for the message!
My system status is now ok, but home page is not working correclty.
Firstly, have a look on system status.
Then please have a look on homepage and then on post or some category.
Notice that for example footer is changed on category, post but not on homepage.
The title of post is changed when You browse category or directly go to post, but not on homepage.
When I try to have a look on category via homepage, it does not shows new post that i created and shoul be located in category Asia.
In summary, my homepage does not shows most of changes I make. What is wrong ?
Hello matpl,
I have checked your website and I have noticed that you do not have any content loaded. First of all, I recommend you to import our demo with the content for making an idea about how it was built and then you have to read all our documentation and understand each element of the theme of how it works. After these steps, you should try to implement yourself this in your website. Do you try to import our demo travel with content? I recommend this way because it more useful (for beginning) to edit existing instead of making something from scratch. Please notice that Travel demo is a custom template and requires more customization performed against the default. I suggest you consulting our Youtube channel, here -> https://www.youtube.com/user/tagdiv because there you will find a lot of useful tutorials in order to achieve best results. Also, you have our demo previews and you can compare them all the time. -> http://demo.tagdiv.com/newspaper_travel/
Please notice that we cannot make your website from scratch but only we can point you in the right directions. However, if you need more assistance after you have read our documentation, please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so I can further inspect your setup page and I will try to give you a helping hand. Also, please provide the link to this topic so we can know who you are and what the issue is.
