Theme fonts WEIGHT
I have set up my BLOCKS/WIDGETS TITLE fonts choosing the weight 200-Extra light but it’s working only on Home Page.
How is that possible that on each other page the font of BLOCKS/WIDGETS TITLES seem to be default/normal?
Thank you for help in advance,
Regards,
LS
If you have set the font properties in theme panel – https://www.screencast.com/t/LyvnjmOk1VY4 it should apply to all the block or widget titles. Try to clear your cache, and also update your Visual composer editor to the latest version – https://forum.tagdiv.com/how-to-update-visual-composer-plugin/ and check to see if the problem is still there.
I have updated Visual Composer, cleared the cache but unfortunately the problem is still there.
Additionally I’d have another question. We are using Tables by Supsystic plugin, where in order to publish the tables on pages we need to use shortcodes. Unfortunately, the tables on pages do not look like the originally set up one (styling, size…) Any idea what might cause the issue?
Thanks,
LS
It seems the Roboto Condensed font has a minimum of 300 font weight meaning the light version – https://fonts.google.com/specimen/Roboto+Condensed Try to enable the following settings in theme panel fonts – https://www.screencast.com/t/5FXjMwBjaXxI The result should be like this, do a cache clear after the modifications just to be sure – https://www.screencast.com/t/c73g5jA6Jrj More about font customization here – https://forum.tagdiv.com/font-customization/
I don’t know what to recommend about that table plugin, if you are using shortcodes and they are correct it should work properly. You could identify the elements on the page and make custom code using your browser inspector to further style and position the table, if the plugin has no settings for this – https://forum.tagdiv.com/create-custom-code-using-the-browsers-inspector/
Indeed, was enough to enable the proper setting in the panel :-).
About the table, guess have to change the plugin..Thank you for the advice!
Thanks a lot!
Have a nice day,
LS
