I’m trying desperately to increase the speed of the site. I got the LCP issue: longer than 4 s (desktop) on google search console. I installed the AMP and Mobile theme plugins and somehow the website was a mess and I had to activate the theme again. The biggest problem is the images and most likely the video section.
What should I do? Autoptimize is a good plugin?
Also, can I change the color of the theme?
Hello !
The speed of your website depends on how well your site is optimized, if you follow the steps which are presented in this tutorial here -> https://tagdiv.com/how-to-increase-page-loading-speed/ you’ll be able to increase the speed of your website.
Also you can check this similar topic for more solutions: -> https://forum.tagdiv.com/topic/optimize-script-to-improve-site-speed/ -> https://www.infophilic.com/get-almost-100-pagespeed-newspaper-theme/
– https://forum.tagdiv.com/topic/a-few-tips-for-newspaper-x-speed-high-cpu-usage-issues/
Also if you want our custom services, you can contact our custom work team here: https://tagdiv.com/premium-customization-services/
