Theme Load Problem ( tagDiv Cloud Library )
Hi everyone,
I’m having trouble adding templates when editing pages. Below are two screenshots. Does anyone know what the problem is?
Note: Add-on board and active
Picture 1 : resimag.com/p1/30ffe99459.png
Picture 2: resimag.com/p1/c489f7cae6.png ( This Problem )
Check your theme to be the latest version of it, installed via FTP way, check the system status parameters to be increased according to our theme’s requirements from here -> https://forum.tagdiv.com/requirements-for-newspaper/, change the PHP version to 7.1 or 7.2, clear all the caches and check the result.
I did what you said but the situation has not changed. What else do I have to do?
Did you have edited the .htaccess and add the mod_substitute rules as you can see our theme’s requirements documentation from here -> https://www.screencast.com/t/V7gETwJz88FK Clear all the caches and check the results. If the problem is still there, please send us an email at contact@tagdiv.com with your log-in information (wp-admin) and Cpanel access so we can further investigate it closer your setup page.
