Theme panel display issue
Hi I have an issue that some icon or images on the theme panel are not displaying.
https://www.screencast.com/t/dCXhCILC
Also some icons and images on post page are not loading either.
I dont really know what causing this issue cause my site runs perfectly and i’ve never made any changes before this issue appear. I am using Newspaper V9.01 and then update it to V9.1 to see if it can fix the problem. But it doesn’t.
Could you please help? Thanks
Try as a first step to force refresh the page in which the theme panel is opened (Ctrl+Shift+R). If that doesn’t work, it could be that the theme didn’t install properly. If possible try and reinstall it by FTP
– https://forum.tagdiv.com/install-via-ftp/
If there is still a problem, send us an email at contact@tagdiv.com and provide admin login so we can take a look. Please include a link to this topic in the email.
