Theme panel > Footer does not display any settings
I have imported a footer from the cloud templates and customized it, and in the end wanted to change the background image. According to the documentation, I should be able to find it in Theme panel > Footer. Unfortunately, there are no settings there!
Check this screenshot: https://imgur.com/a/5hg9ZaG
Because you import a footer from Cloud Template, the background image need to be set with tagDiv Composer, on the row on the footer section in the tab called “CSS”=> https://www.screencast.com/t/icgswNVnEwOY
Hope this helps you!
Hey Anamaria,
I’ve tried doing what you asked but even when I upload the new image the footer doesn’t update for some reason.
I’ve tried purging my cache but it still doesn’t work.
https://www.screencast.com/t/eqo5q1tvwvX
Hello, @heitoradines,
Please make sure you add the image on the row on the footer => https://we.tl/t-5ZGaoxW2ky
Also, if the change will not apply please do a test using only tagDiv plugins and see if the problem persists.
