I have tried multiple broswers. When adjustments are made within the theme panel it stays stuck on loading without saving the new setting.
The first thing to check would be the theme requirements, system status section
It is imperative that the parameters mentioned in the guide are configured properly. Insufficient resources can cause many issues with the theme or the plugins, if needed ask your hosting provider to increase them as specified.
If there is no need for that, or after making changes it still happens, check if there are any errors in the browser inspector console, while saving a setting in the theme panel.
Server security modules or firewalls may block the admin ajax denying access. In similar cases the issue was caused by that
– https://forum.tagdiv.com/topic/cant-save-theme-options-2/
