I am trying turn off author, dates, views, comments, tags, etc from all posts. When turning off these options from the theme panel >> post settings – the theme is not responding and all of the above still showing on posts. Am I missing something? I appreciate your help.
Thank you
F-
Maybe the settings made in the theme panel are not being saved for some reason. If you disabled those, they should not be displayed anymore in the post page.
The quickest way to check would be to provide admin login for the website, you can send them by email at contact@tagdiv.com. We will investigate the problem as soon as possible.
Hi Simion,
Thanks for responding to my post. I will follow up with an email as recommended. I just installed the theme and have not knowingly disable the theme panel entirely. I did not know this is even possible. Is there a way to check before emailing and waiting for contact@tagdiv.com to respond? I urgently need to make global changes to the site and stay on track with my project target date.
Quick questions:
– How to edit and remove tags from the Pulse PRO theme?
– Is there a design guide document that I can use as reference to find the easy “how-to” answers?
Thanks for your help.
Fabiano Da Silva
If the theme panel does not appear, that would mean the composer plugin is deactivated. The composer plugin is required, the theme panel and other theme pages won’t be available without it – https://prnt.sc/udf94k Please check if its active.
The Newsmag theme does not have a Pulses PRO demo. You must be referring to Newspaper. I will move the topic in the Newspaper forum.
Pro demos use cloud templates fully. These templates must be edited in the composer, there you can customize it as needed, and add/remove elements. If you are reffering to the cloud post template, you can edit it with the composer and remove the tags from there https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
So for example https://prnt.sc/udfc7g -> https://prnt.sc/udfcna
Let me know if you have more questions.
Aloha Simion,
Thanks for the reply.The composer plugin is installed and appears to be active https://paste.pics/A2KLM. When I make the selection on theme panel it does not change anything, only from the
I thought this topic is under the “Newspaper” forum – it says it at the top or maybe you already moved it – thanks for doing so.
The screen shots were helpful. I do not get the same options for editing the tags. I tried clicking on roll, column, element or roving over the tag element but nothing showed under it – https://paste.pics/A2KMW.
Please let me know if think there is something with the template install and what options would you recommend.
F-
I tried to view the screenshots but none of them work unfortunately https://prnt.sc/ue9c1o
Maybe it would be better to continue this by email at contact@tagdiv.com
There you can provide a link to the website and admin login, so I can provide more accurate assistance while actually seeing what you are referring to, and also check if there are any issues. Include a link to this topic in the email.
