Hi, I was trying to customize the look and feel of the post on my website but somehow some of the functions don’t properly, I had to go to the post individually to disable comments
e.g I disable the following but it still appears on my post
“Show Author box”
“Show Next and previous post”
“Enable Comment on Posts”
Please see https://thatcontentguy.sg/culture/how-anti-excess-content-is-saving-beauty-youtube/
This is a single post template from tagDiv Cloud Library, these need to be edit with tagDiv Composer and add/remove elements you want, the settings from theme panel will apply only on standard templates, not on these from tagDiv Cloud Library, or PRO demos.
Hi Calin, or so you’re saying the theme panel does not work with single post template, but what should I do if I want to make wholesale customization to all my post? Can you give me some instructions on how I should go about doing that?
Hi aysasi,
Please check this topic -> https://forum.tagdiv.com/topic/upgrade-from-newspaper-9-to-10-broke-shortcode/#post-323782
Hi geraldho81,
The settings from theme panel will apply only on standard templates, the new templates, these from tagDiv Cloud Library need to be set individually, if you have a single post template, this can be set individual -> http://prntscr.com/pu3vuz or global will apply on all posts the have set “From panel” -> http://prntscr.com/pu3w1h -> http://prntscr.com/pu3wyj so the solution is to set the post to have a global single post template and if you want you can set individual single post template too ( this will overwrite the global option).
Hope this will help you!
