Theme Panel Settings and Template Changes do not work
Hi Support,
i have installed the latest newspaper 12.4 Version and the Prebuilt Website Installed: Magazine PRO
When i do some changes in the Theme Panel then this changes will not happen…….no colors, no items, no social media…
then i changed and installed a child-theme….but there is the same problem ;-(
NO CHanges taking any effect
Can you help?
regards,
Mike
Hello Mike,
The options from the Theme Panel are for the standard template, but you have a Pro Prebuilt website and this uses cloud templates, which can be edited with tagDiv Composer ->https://www.screencast.com/t/UeBGkaYuundl, go to the footer and select the element you want to edit => https://www.screencast.com/t/3vhZ5v4k and change the description.
The same steps are for all templates -> https://forum.tagdiv.com/footer-templates/
Our theme is a frontend theme for most of the elements and changes, you’ll need to use the tagDiv Composer to edit the pages and templates for posts/categories, etc => https://i.imgur.com/I3OUYxr.jpg -> https://i.imgur.com/mMrEufY.jpg from the frontend, no in the code -> https://www.screencast.com/t/LDdokrHPl
Also, this is a video on how to change the logo -> https://www.youtube.com/watch?v=HXQQygkCCJo -> https://forum.tagdiv.com/add-logo-newspaper/
The theme accent color it only applies to certain elements, for example, to back to top button.You can copy and paste the style from one block to another.
You can use the Global Colors option from Manager -> Global Colors -> https://i.imgur.com/PM6VoBL.png
Thanks for fast reply!
I’ll try with your hints now…
in Chrome:
https://bamaka-marketing.de/ shows no content at all now?
in Firefox it gives this error message:
Content-Encoding-ERROR
Can you help why the browser don’t show the website?
regards,
Mike
I checked and it is displayed in Chrome -> https://i.imgur.com/SLict7x.png so, you need to edit with tagdiv Composer.
Here is a video that will show you how to use the builder to create a website from scratch https://www.youtube.com/watch?v=SoGQ0d5kIBg
