Try with all plugins disabled, could be a conflict in javascript. If not work can you give us access to wp-admin to take a look. Send via email at contact@tagdiv.com
Please also check if the admin-ajax.php file can be accessed. Some hosts block access to the admin-ajax.php file when saving your settings and with that file blocked the theme can’t save your settings.
If this is your case contact your host provider and let him know about this issue.
You could easily identify if this is happens in your case by checking you browser’s console while saving your settings.
Please also let us know if you have tried this in your message and also provide a link to this tread if you haven’t send your message already.
If you have this issue – https://forum.tagdiv.com/topic/theme-activation/#post-44037 please try to replace (overwrite it) the td_panel_categories.php file – http://screencast.com/t/rnRNRNL1Ri with the one provided in the following link – https://www.dropbox.com/s/tegdpkwb43z9air/td_panel_categories.zip?dl=0
