Theme Panel > Theme Fonts not loading
Hi there!
I’m having trouble editing the font size of titles in the option: Modules and Blocks – Article Title from the Theme Panel. When I click it, it seems to be loading but never expands so I can edit the options.
How can I fix this?
Thanks in advance!
If I understand correctly you say that this section do not appear to you https://www.screencast.com/t/3BmckAC1
Please try to deactivate all plugins that are non theme, clear all cache and try again.
Also please make sure that the theme system status is configured as mentioned in the requirements guide. Please follow the guide carefully
Increasing WP_MEMORY_LIMIT to 256M fixed the problem.. Now it appears correctly!
Thank you very much!
