Theme Setting Keep losing after a couple of months
I don’t know why but my theme is keep losing its setting after a couples of months (sometimes even after 20 days) … It reset theme setting to default like when you install first time the theme and ask you to activate theme.
Any suggestion?
This could happen if the system status parameters are not set correctly: https://forum.tagdiv.com/system-status-parameters-guide/ or caused by certain plugins. Recently, we have reports of wordfence causing issues with the theme panel. Please try to deactivate any untested plugins.
system Parameters are set correctly. I think problem was with Wordefence plugin. I removed it and installed All In One WP Security & Firewall
It working fine right now, but i face this problem again than i will contact you. But can you please recommand us which security plugin we can use with this theme?
Wordfence created a few issues regarding the theme settings, but there is a way to set it up to work properly again. Please follow this topic: https://forum.tagdiv.com/topic/cant-save-theme-settings/
