http://prntscr.com/fmztzb
Here is a screenshot of the problem.
Just bought Newspaper 8
Maybe something went wrong during the theme installation. I suggest you reinstall the theme using this method
– https://forum.tagdiv.com/install-via-ftp/
Also a plugin could be causing this problem. You could uninstall all you plugins except the ones that are provided in the theme package, and clear any caching installed.
That does not mean that a plugin is not the cause in this case. If you reinstalled the theme, it is necessary to rule out plugins. The Newspaper 8 theme panel is not being displayed properly. This is how it should display
– https://www.screencast.com/t/lVEOv7l7a2R
Try the suggestion with the plugins and see if this has any effect. Please let us know the result.
The images are located in this folder
– https://www.screencast.com/t/GtLZ3pc7a2I
That is where the theme panel images are located. You can check in the theme package you are installing and see if it this folder is present.
Please send us an email at contact@tagdiv.com and provide admin login information. FTP access may also be required so please provide this as well. We will take a look and try to identify the problem.
Also paste a link to this topic in your email, so we can identify you.
